Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Maxgur
Jul 15, 2020Guide
The problems remain. At a frequency of 5 GHz, the channel is reset to 36. Sometimes, communication with devices connected at a frequency of 5 GHz disappears. I can not connect to the hard drive that is connected to the router. I hope that they will fix the problems in the new firmware ...
Indrajit
Jul 15, 2020Guide
My router shut down completely and doesn’t communicate with PC or Netgear app at all, no internet connection at all, it’s totally dead. I tried everything possible can, not responding to anything. Disappointed very much. Got this router in December 2019, Netgear will not do anything unless I purchase their service.
- kvik369Jul 15, 2020Guide
Just curious - I actualy have a RAX35 with the same issue I'm powering the router off and on in the AM with a hardware timer. Usually this keeps it fine the whole day but sometimes I still lose internet and have to power cycle the router again Thanks for the update
- UpsetCustomer98Jul 17, 2020Initiate
This is so incredibly frustrating. With everyone trying to work from home and Netgear bricks our routers. I am having all the same issues described here. I will try to put back the older firmware and hope that helps. This is absolutely rediculous.
