Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Indrajit
Jul 26, 2020Guide
I followed the directions to factory reset several times, that didn’t help. My router is dead, doesn’t communicate with anything.
BuckeyeRay
Jul 26, 2020Tutor
Did you plug in directly? Once I did the factory reset I was able to get in using default logins and a direct ethernet connection. I rolled back the firmware and everything is fine again. I also turned off auto-updates.
