Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
benoit_fr
Jul 26, 2020Apprentice
Hello all,
Here is a quick update following multiple failures right after the latest FW update.
- I disabled Smart Connect. I am using (like with previous FW, the same SSIDs for 2.4 and 5ghz)
- I disabled Mix mode WPA2/WPA3 and using only WPA2 AES
3 weeks without any issues.
Hope this help. I stick with the latest FW without any new FW "benefits"...
Best
- benoit_frJul 26, 2020Apprentice
as a precision : 4 ethernet devices and 22 wifi permanent devices at home...
- scott2003lhsJul 26, 2020StarCool. I gave up. Get firmware corrupt red light then reboot. Then works 12 hours. I ordered a premium expensive router from another brand. I’m fed up. Netgear is a shell of their past
- ncdancerJul 30, 2020Guide
benoit_fr, Are you on .80 with no problems? I downgraded to .64 over a week ago also no problems yet.
- Rkohl1956Jul 30, 2020GuideI downgraded to 64 after my first spate of problems w 80. Never looked back as I’m running fine w 64. I’ll give the next release a looksee when it comes out, but have no interest in dealing w 80 at this point.
- benoit_frAug 02, 2020ApprenticeBack to 0.64 firmware due to WiFi problems.... Please Netgear tell us that at least you identified stability problems..
