Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
benoit_fr
Jul 27, 2020Apprentice
Hello all,
Here is an article in french (google translate is your friend...;))
https://www.cachem.fr/sonos-et-synology-probleme-de-wifi/
It's dealing with problems with Synology / Smart Connect and Sonos speakers.
I also have Sonos speakers and was having issues with Wifi and Smart Connect
Multicast translation (and IGMP snooping in a mesh Wi-Fi system) seems to be an issue on the Syno router FW.
May be something to look at / double check for Netgear engineers ?
My two cents
