Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
pbulteel
Aug 25, 2020Star
I say this with all sincerity. You just bought this router. get your money back. Run for the hills. Save yourself. There's cheaper stuff out there that's a million times better than this. It's not worth trying to get this working.
Eagle-Two
Aug 25, 2020Apprentice
Thanks but I actually purchased the router a while ago and I'm just now getting around to setting it up. Unfortunately its past the return date. The RAX35 seems to perform and work good immediately after a power cycle.
- Eagle-TwoAug 25, 2020Apprentice
This evening my WiFi 6 phone disconnected from the router and wouldn't reconnect on 2.4Ghz or 5Ghz. The wifi was cycled on the phone but still wouldn't reconnect. The router showed the phone as an attached device and I didn't see anything unusual in the router logs. After I disabled AX on the router, the phone reconnected and I haven't had any connection issues.
