Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
TOKEN_
Aug 27, 2020Tutor
Christian_R how are you going with the net gear teams you where in contact with. You have been very quiet on the topic considering you where asking for more information so you could pass to the support teams.
Eagle-Two
Aug 27, 2020Apprentice
Yesterday all of my devices on the 5Ghz band wouldn't connect to the router. They would connect and immediately disconnect. The 2.4Ghz band continued to work fine. After rebooting the router, everything worked properly again. Is there a way to reboot the router on a schedule? Is there a way to submit a bug report to Netgear after the technical support period ends? This weekend I might try downgrading the firmware.
