Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Retired_Member
Aug 27, 2020Just wanted to tell everyone here that Netgear is currently developing a new firmware for the RAX40! I have been working with them and this weekend I am going to be testing a beta firmware. So hang tight.
ronald_fr
Aug 28, 2020Luminary
Hello
I’m testing a new version of the 80 f/w
This beta works a lot better
Best regards
Ron
Best regards
Ron
- kvik369Aug 28, 2020Guide
Any idea if they're also working on the firmware for the RAX35?
- regghkAug 28, 2020Aspirant
Hello Ron,
Recently I find it is very consistent that the RAX40 router will drop wifi when I start facetime with my iphone for few minutes. see if you could test it with the beta version and report any issue to netgear, thx
Re
- Retired_MemberAug 30, 2020
I tested the new beta a bit this weekend. It is more stable however still doens't work with the EAX20 Extender and my iPhone X was constantly dropping off the Wi-Fi while using Smart Connect. Still ways to go.
- TOKEN_Aug 30, 2020TutorFed up. Will be returning this and going with something. Fecking useless support from netgear.
