Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Maxgur
Sep 02, 2020Guide
Support doesn't answer at all. Netgear react to user messages. When will the new firmware be released with the elimination of user comments?
ronald_fr
Sep 02, 2020Luminary
Hello,
I got a new beta a couple of days ago.
As asked by regghk, I have just tried a facetime session (20 min long), and I have not been disconnected or .... (no issue).
(I don't use WPA3 nor smartconnect)
Best regards
Ron
- Eagle-TwoSep 03, 2020Apprentice
Ron,
Have you used AX over 5Ghz with the new firmware? I was having random disconnects with that configuration. - Retired_MemberSep 03, 2020
Those need to work. I use them and they are still unstable. It's an expensive piece of hardware to not be able to utilize its full potential. If you are submitting debug logs to Netgear, I would turn those options on.
