Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
sreenuraj
Sep 12, 2020Tutor
Hi all
I had almost all the issues mentioned in this post when I upgraded to 1.0.3.80 so not repeating those. I raised an issue with the support and after 2 to 3 weeks to and fro communication with them, they decided to replace my router.
I was aware of the 1.0.3.80 firmware issue from these channels but I decided to give this replacement a try. The device was out of stock for more than a month and got the replacement on 2020-09-09.
Upgraded the replacement router to 1.0.3.80 firmware and Its been 4 days now and I can say that I am not facing any issues with it. Not even one time I had restarted the router and there is no siggnal drop or router been going to a hung state.
I will update if any issues in future, but now I am beleving that the there was a hardware issue.
Any one else in the community tried with the replacement? I think all should try to get a replacement if possible.
Thanks
Sreenuraj
Gioel_Assecondi
Sep 17, 2020Tutor
All this is quite disheartening: I bet on Netgear for their quality by taking also an eax20... if it was a hardware problem, in Italy their support is paid, should I open a support subscription to have my router replaced? No thanks....
sreenuraj wrote:Hi all
Thanks
Sreenuraj
I will try first with Amazon because luckily I got it through them.
