Anonymous
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
carminea
Sep 27, 2020Star
Part problem is the netgear nighthawk app is forcing people to upgrade. When one logs into the app it tells you update and you cannot go further.
itsmehuey
Sep 27, 2020Luminary
My netgear nighthawk app does not force me to update. It tells me that an update is available but does not force me to download/install it, and am able to continue using the other features. I have turned off automatic updating if that makes a difference.
- jaf2020Sep 29, 2020Aspirant
Acknowledgement that there is an issue and that a fix is under development would go a very long way... instead, it is months of radio silence. That leaves me with the sense that this is not a priority for Netgear.
- carmineaSep 29, 2020StarWell maybe like this article says and many others on the internet, it might be just junk that they cannot fix it
https://www.tomsguide.com/news/netgear-routers-no-fixes
