Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
dmwalsh
Oct 01, 2020Aspirant
Hi there, having the same problem with my router, dropouts, what can be downe to fix this?
- itsmehueyOct 01, 2020Luminary
dmwalsh wrote:Hi there, having the same problem with my router, dropouts, what can be downe to fix this?
if you read through all of the threads and posts pertaining to this issue that everyone is having, the only things that can be done:
- return the router if you are able to (most suggested option as this router is absolute garbage)
- keep the router and revert the firmware to the previous version until Netgear fixes the firmware and releases a new version of it (don't keep your hopes up for this to happen any time soon).
