Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Eagle-Two
Oct 03, 2020Apprentice
My router with 1.0.3.80 recently locked up at an inopportune time. About a week earlier I switched to a wired connection but the router still completely froze up on me dropping all connections including LAN. I checked the modem and it didn't show an active LAN connection on the RAX Ethernet cable. I had to power cycle the router. In addition to the random disconnects, I also randomly get this router freeze.
Today I downgraded the firmware back to 1.0.3.62 and reset the router. I'm now using AX once again so I should know in less than a week if the downgrade helps with stability. In reviewing the Netgear discussion boards, I see several Nighthawk router models from RAX35 to RAX120 reporting disconnects. I'm wondering if there is a common feature or configuration causing the issue.
regghk
Oct 04, 2020Aspirant
common, you'd read the entire thread to see various problem, no new fireware out yet to solve this.
- itsmehueyOct 05, 2020Luminary
quite pathetic I say. Netgear have released new firmwares for other RAX devices to try fix the similar issues on those but noticed that issues are still occuring. And with no resolution in site for us RAX40 users.
