Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
benoit_fr
Oct 05, 2020Apprentice
This is my last message here.
Full refund of my router this weekend...
Happy man ! ;)
Good luck to all of you !
- kvik369Oct 05, 2020Guide
good luck to you too - mine is sitting in the corner getting ready to go kin the garage/garbage using an older Tp-Link
- itsmehueyOct 05, 2020Luminary
benoit_fr wrote:This is my last message here.
Happy man ! ;)
Netgear should take back these routers and refund everyone.. this is such a criminal act to sell a product with faulty firmware and then expect people to pay for a support/service plan for them to do anything about it.
- Eagle-TwoOct 05, 2020Apprentice
I had my first issue with firmware version 1.0.3.62. On my Wifi-6 Galaxy phone, the internet began to run choppy then sites failed to load. Finally I lost connection to the router and the phone would no longer reconnect to the router over 2.4Ghz or 5Ghz getting a unable to obtain IP address error. All of my other Wifi devices are not Wifi-6 and didn't have any connection issues. I decided to disable AX on the router and reboot. Now my phone connects to router once again but not using Wifi-6. I also had similar issues with AX when I was using firmware version 1.0.3.80.
Eagle-Two wrote:I had my first issue with firmware version 1.0.3.62. On my Wifi-6 Galaxy phone, the internet began to run choppy then sites failed to load. Finally I lost connection to the router and the phone would no longer reconnect to the router over 2.4Ghz or 5Ghz getting a unable to obtain IP address error. All of my other Wifi devices are not Wifi-6 and didn't have any connection issues. I decided to disable AX on the router and reboot. Now my phone connects to router once again but not using Wifi-6. I also had similar issues with AX when I was using firmware version 1.0.3.80.
ridiculous that you'd need to be disabling a feature which was touted by the marketing of the router in order for it to provide even the basic level of networking capabilities....
