Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
jweaver4475
Oct 30, 2020Aspirant
I'm using firmware 1.0.3.80 and have been experiencing issues, wifi dropped out today and some devices did not recconect without a reboot. Could someone from support get me in the beta tester program? I would like to assist in finding bugs/issues with this device.
Also it seems that the router is changing channels or using other channels then the one selected, not even when using DFS channels.
- jweaver4475Oct 30, 2020Aspirant
Also I am only able to select channels 36-64 while using 160mhz (up to 2400mb/s),
Is this a bug? Should I be able to use UNII-3 channels 149-165?
I know only 149 or 150 whould give the full 160mhz wide channel.
