Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
itsmehuey
Nov 01, 2020Luminary
MrLRC wrote:Found this thread and I cannot believe almost 6 months now and they didn't fix the firmware, and the broken firmware is still auto updating to our router!
Have you tried disabling auto-update in the router's admin console?
jweaver4475
Nov 01, 2020Aspirant
I seen this post on the netgear RAX40 support page, probably not a great idea to run old firmware as it appears there is a security misconfiguration.
Security Advisory for Security Misconfiguration on RAX40, PSV-2019-0267
https://kb.netgear.com/000062356/Security-Advisory-for-Security-Misconfiguration-on-RAX40-PSV-2019-0267
They advise to update to the latest firmware. This is an issue is on firmware prior to 1.0.3.80. So if your running previous versions you could be at risk. Hopefully they fix the firmware but, it doesn’t seem like it.
I chatted with support and they couldn’t answer any questions I had about my router. Waited 45 minutes without a reply to a basic question and I’ve also posted a few questions on here but, it doesn’t seem like any netgear support are active in the community or they are just dodging any post about this router.
- itsmehueyNov 01, 2020Luminary
jweaver4475 wrote:
Waited 45 minutes without a reply to a basic question and I’ve also posted a few questions on here but, it doesn’t seem like any netgear support are active in the community or they are just dodging any post about this router.Do what I did and have the matter escalated to L2 support by Christian_R Netgear support are really dropping the ball... I've been able to get in contact with L2 to provide me with a link to test out the beta firmware but apart from that, it's all radio silence since then.
