Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
ExcelsiorNY8
Nov 06, 2020Aspirant
itsmehuey where did you get the beta your currently using? Do you have this engineer’s email? Thanks!
itsmehuey
Nov 06, 2020Luminary
Sorry but no I don’t have their email. So communications were done through Netgear level 2 support who were provided the beta firmware from the engineer team. You’d need to raise a support case with Netgear which will go to L1 support first. I had to go through so many hurdles and required the assistance of one of the mods here to escalate my initial support case to L2.
- vijaygopal81Nov 08, 2020Tutor
Could you share with us the beta firmware?
- itsmehueyNov 08, 2020LuminaryBeta cannot be shared unfortunately. It will be a breach of the T&C of use. It can only be obtained directly through support.
Ok no problem. But how is the performance of Beta? Did you face any issues since then?
Also did they inform you when the final version will be out?
