Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Newfiedrool
Nov 19, 2020Virtuoso
This why Betas should be behind closed doors. If nothing was mentioned you would not be asking for it to be shared and with some Betas it can void warranty.
im sure they will release an update, like all routers especially a AX routers it can take a while to became stable as the chipset manufacturers release updates to drivers.
my RAX120 was in the same boat and runs well now. Im sure it will soon come out and may include a security patche too.
Profinet
Nov 19, 2020Star
I'm sorry but while I would normally agree with you on this.... my warranty is going to void based on expiry with the time it is taking to release a working version of this. A week or three of constant hanging and reboots when I have critical systems integrated is somewhat acceptable (not really but I have patience). 6-10 months now of the issue is wholly unacceptable. They need to do better for their customers and they should've had ample time now to test this "beta".
