Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Retired_Member
Dec 26, 2020Received the RAX43 yesterday and set it up today. You can tell they refined the product. Firmware has the same UI with minor updates (they added Netgear ARMOR subscription service) however so far it is stable. Please everyone, work with your reps and get this router, if they agreed to replace mine, yours should get replaced too.
I will follow this thread for your progress, and I will also continue to test incoming firmware's for RAX43.
Happy Holidays, Merry Christmas and a Happy New Year to you all!
grumpyolman22
Dec 28, 2020Star
The RAX40 is clearly Consumer Fraud. It doesn't work, even with the latest firmware, and never worked as advertised so they are simply stalling until the warranties run out. After that, you are out-of-warranty and out of luck. Contact your state's consumer advocate.
