Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Rubes09
Jan 28, 2021Aspirant
Hi, thanks for starting this thread.
I have an RAX40 running V1.0.3.80_1.0.1 firmware.
Was experiencing multiple dropouts per day. Spoke to my ISP - they confirmed it is a router issue.
Also purchased an EAX20 extender. Would not connect to RAX40.
Followed advice from this community and downgraded firmware to V1.0.3.64_1.0.1
At least I can connect the extender now. Shame it no longer has Smart Connect.
Have lost many days to this router. Netgear phone support was completely useless - told me to return my extender because it's faulty!
I'm waiting for confirmation that the 1.0.3.88 firmware won't brick my router. Would really prefer Smart Connect than having to manually select.
Cheers
- pbulteelJan 28, 2021Star
My recommendation to you is ... return it and get your money back if you can.
Run, don't walk... This is the biggest piece of garbage I have ever had.
Buy anything else.
I'm surprised nobody has started a class action for this.
- ronald_frFeb 02, 2021Luminary
Hello All,
this is my very last message : again the same issue (I was so confident); now I'm at the end!
So I went to my provider. They were ok to give me money back w/o any discussion.
I added 30€ to obtain a brand new rt-ax82u ... So for any issue (?) I have to change community.
Good luck
R
- ProfinetFeb 02, 2021Star
Should've insisted on a replacement to a router that works... V1 is garbage.
Worked for me, first try
