Anonymous
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
nilon123456789
May 19, 2021Tutor
Update on my last post. The new update is fine most of the time but some days I'm experiencing lost of internet connection. The local network kinda working but I can only ping the router. I tried using Google DNS without success. So I don’t really know what to try.
itsmehuey
May 26, 2021Luminary
ok having major issues trying to access router admin page via browser.. anyone else? any fix? Christian_R you will need to raise this with your team as a major fault with this firmware release.
- Christian_RMay 27, 2021NETGEAR Employee Retired
Hello itsmehuey,
Thanks for looping me in. Are you still experiencing issues with accessing the admin page via web browser?
Christian
- itsmehueyMay 28, 2021Luminary
Christian_R wrote:Hello itsmehuey,
Christian
Christian_R yes I am, and if you look through the last couple of replies on this post, you'll notice that many others are as well.
When trying to access the admin console through 192.168.1.1 AND routerlogin.net, the browser redirects to https://www.netgear.com/home/services/routerlogincom/ which states "You may not be connected to your Router’s WiFi network. To access routerlogin.com, your device must be connected to your Router’s WiFi network. Check your current connection and try again."
This makes absolutely no sense as I'm clearly connected to the router in order to access this community via Internet.. The only way I can access the (limited) admin functions is through the Netgear Nighthawk app on my phone.
This is a major flaw.
- Christian_RMay 28, 2021NETGEAR Employee Retired
Hello tsmehuey,
May you send me a private message with the following info. I'd like for our support team to reach out.
Email:
Phone:
Preferred Contact Time: (including time zone)
Router Serial Number:
Thanks,Christian
