mae_sikder
Feb 23, 2021Aspirant
RAX40 freezes broadcasting
I have bought 10nos nighwalk AX3000 router for my office. But i am in extreme trouble- these routers stops broadcasting SSID or do not release IP to clients or sometime gets default configauration autometically. I tried with 3 routers, all have the same issue. No one is performing well. No firmwire uapdate is availble in online. Please help.
- Christian_RNETGEAR Employee Retired
Hi mae_sikder,
Have you had a moment to perform a factory reset on your router(s) by holding down on the reset button for 15+ seconds using a pin/needle?
Christian
- mae_sikderAspirant
Yes I did. After factory reset I can get access, configure the device and with in 2-4 hours it becomes auto factory setting or stops broad casting or stops accepting new device. I am facing this problem only with this model. Other netgear AC series is quite stable.
Last day I have downloaded a firmwire from website and implimented it, Since then it works fine. But I am still worried.- Christian_RNETGEAR Employee Retired
Hi mae_sikder,
Please feel free to provide an update regarding your issue on the current firmware version you're on.
Christian
