mae_sikder
Feb 23, 2021Aspirant
RAX40 freezes broadcasting
I have bought 10nos nighwalk AX3000 router for my office. But i am in extreme trouble- these routers stops broadcasting SSID or do not release IP to clients or sometime gets default configauration a...
Christian_R
Feb 25, 2021NETGEAR Employee Retired
Hi mae_sikder,
Please feel free to provide an update regarding your issue on the current firmware version you're on.
Christian
mae_sikder
Mar 04, 2021Aspirant
Thanks for the support. I have implemented V1.0.3.88_1.0.1,
As per Netgear Suggestion (https://kb.netgear.com/000062596/RAX40-Firmware-Version-1-0-3-88), it says-
- This firmware version does not support OFDMA, WPA3, and Smart Connect. If you wants to use these features, roll back the firmware to the last version V1.0.3.80.
Whatever, I had to establish a stable connection threre I did that. Till now connection is stable. I intentionally overlooked 2 features -Smart Connect features and OFDMA.
Infact, we dont expect such problem from netgear. TP-link and other brand works better in Bangladesh. But Netgear has good brand image...!!
