Say_What
Oct 31, 2021Aspirant
RAX40 Nighthawk 5 g connection issue
I am logged into my Router and see wifi 2.4 g connection, I scroll down to 5 g connection and see it is greyed out. My computer is logged into and wifi connected to the 2.4 g connection. I cannot get...
- Oct 31, 2021
Thank you for reaching out on a Sunday! I had a device listed that was not my phone name that was blocked. When I checked my phones IP and Mac address that was the device that was mis labeled and blocked. I renamed it and unblocked it and wala my phone is connected. You deserve a pay raise, promotion and 2 week all expenses vacation anywhere in the world! Have a great day!
Say_What
Looks like I might have combined 2.4 G and 5 G on one network. Netgear Nighthawk app speed test on computer shows Download 464.91, Up load 23.16, and Ping 29 MS. The only problem I have is connecting my Android Pixel 5 phone. I see my Pixel 5 is not listed as a device on my network. Seems all I need to do is a my device?
- plemansOct 31, 2021Guru - Experienced User
so yes, smart connect does combine the ssids for the 2.4ghz and 5ghz signal.
The devices can switch between the 2 networks.
It shouldn't stop your pixel 5 from joining the network at all.
What error are you getting?
Are you using any special characters in the ssid/password? If so, I'd remove them.
- Say_WhatOct 31, 2021Aspirant
- FURRYe38Oct 31, 2021Guru - Experienced User
For your future needs, Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
Never mind I figured it out. Pixel 5 phone update changed my settings. I drilled down and everything is working on one network with 2.4 and 5 G combined in smart mode.
