IAmNamedKevin
May 15, 2020Follower
RAX40 Orange Internet LED Light
I have a Nighthawk RAX40. I was able to set up via the Nighthawk App when I purchased the router. I have not used the app since, and it's been about 8 months since set up. I noticed recently that...
May 15, 2020Guru - Experienced User
1. What modem is it connected to?
2. Firmware on the router?
When you say your internet connect isn't as strong as you were expecting, are you talking coverage, tested speeds?
the AX spec allows a little more coverage just because its more efficient at transferring data but the actual broadcast power is limited by the FCC so there isn't much additional distance.
The other thing to keep in mind, a lot is dependant on your devices. You've got an AX router but do you have AX devices?
