Frustrated_cust
Jul 24, 2020Initiate
RAX40 Router. Anyone can share working firmware and setting for this router ?
Hi,
Anyone know a stable Firmware and settings that they are using to make this router work?
I tried last 4 firmwares including the latest firmware.
Issue with latest firmware (V1.0.3.80): Wifi and ethernet works for few hours and the both wont work until a reboot. I have to reboot multiple times in a day.
Issue with 3 old versions (V1.0.3.6X_1.0.1): Wifi wont work at all and ethernet works.
Please help. I am trying to find last options before I buy another router.
Thanks,
- Christian_RNETGEAR Employee Retired
Hello,
Welcome to the community! Have you had a moment to get in contact with our support team regarding your issue(s)?
https://www.netgear.com/support/default.aspx
Christian
- Frustrated_custInitiate
Yes, I did contact support multiple times.
therese are current case numbers.
43116801
43134283there was one more case number prior to this.
