Louis551
Jul 23, 2020Aspirant
Rax40 router locks up
Hi all my router locks up once a week or more have the newest firmware V1.0.3.80_1.0.1 have to unplug and wait 1 minute. Of course you have to pay netgear to talk txt them. 🤬 any ideas? Louis
sbonenfant
Sep 24, 2020Aspirant
I have the exact same issue with Firmware Version V1.0.3.80_1.0.1
This is very frustrating when you have all the entire family relying on internet access with remote work and school.
- HarishBSep 29, 2020AspirantI have the same issue. Got the device replaced 3 times but no respite. It freezes every day!!
- itsmehueySep 30, 2020LuminaryNetgear don’t care and they should recall their rax routers until they can fix the damn issues with their firmware. They released an incomplete and buggy product.
- MeesKeesOct 06, 2020Tutor
I had the same problem with firmware to V1.0.3.80_1.0.1 .
Switched auto update off en go back / install the firmware V1.0.3.64_1.0.1
I have nog problems anymory, so this solved the problem for me...- MeesKeesOct 06, 2020Tutor
Switch auto update off and go back/install firmware V1.0.3.64_1.0.1
I have no problems anymore, so this solved the problem for me...- itsmehueyOct 06, 2020Luminary
yeah shouldn't be considered as a fix though. a fix would be to actually correct the issues with the firmware.
