Louis551
Jul 23, 2020Aspirant
Rax40 router locks up
Hi all my router locks up once a week or more have the newest firmware V1.0.3.80_1.0.1 have to unplug and wait 1 minute. Of course you have to pay netgear to talk txt them. 🤬 any ideas? Louis
sbonenfant
Sep 24, 2020Aspirant
I have the exact same issue with Firmware Version V1.0.3.80_1.0.1
This is very frustrating when you have all the entire family relying on internet access with remote work and school.
MeesKees
Oct 06, 2020Tutor
I had the same problem with firmware to V1.0.3.80_1.0.1 .
Switched auto update off en go back / install the firmware V1.0.3.64_1.0.1
I have nog problems anymory, so this solved the problem for me...
- MeesKeesOct 06, 2020Tutor
Switch auto update off and go back/install firmware V1.0.3.64_1.0.1
I have no problems anymore, so this solved the problem for me...- itsmehueyOct 06, 2020Luminary
yeah shouldn't be considered as a fix though. a fix would be to actually correct the issues with the firmware.
- itsmehueyOct 07, 2020Luminary
OK folks we may be getting somewhere. I just got off the phone with a L2 support rep as my case was esclated by Christian_R. I was provided with an updated beta firmware (RAX40-V1.0.3.83_1.0.6) which I'll be testing over the next day or so. All seems OK at the moment but it's still too far to tell. I currently have AX disabled, but I will be enabling it soon to see if it works on this firmware version.
Also, I no longer have issues with my TP-Link KASA KP303 smart power strips crashing my router whenever it tries to establish a connection.
Fingers crossed this beta will be good to go to be released as an official build.
