jvamos's avatar
jvamos
Tutor
Sep 09, 2020
RAX40 router stability driver issues
I am having stability issues with the latest firmware. Are there any devices known to cause issues with older drivers specifically? I have seen it mentioned elsewhere in the forum.
  • plemans's avatar
    What stability issues are you having?
    What firmware are you on?
    What modem is it connected to?
    Was there issues prior to updating the firmware? if not, a reasonable first step for issues after firmware changes is to reset/reinstall.
    • jvamos's avatar
      jvamos
      Tutor
      hey plemans,
      I did everything short of a reinstall or reflash. I have tried turning off some extra features as well. V1.0.3.80_1.0.1 is the version I am on presently.
      The issue is the router locks up and the radios seem to go offline. I haven't tried accessing it via the browser during one of these lockups yet. I have just used the power switch to cycle the router.
      I have a switch connected as well. The modem doesn't seem to be the issue.
      I have had stability issues on a previous version as well.
      • plemans's avatar
        I'd start with the factory reset first.
