tk3000's avatar
tk3000
RAX40 Router unable to assign a reserved IP to some devices (MACs)
Hello, My router normally assigned IP dynamically via its dhcp server. But, in order to keep track of my devices more consistently, I decided to assign specific IP addresses to specific devices (MAC...
  • Kitsap's avatar
    Kitsap
    Aug 21, 2022
    Salt that sequence away, "once I rebooted the router a second time..." you will use that again in the future.
    You had me shaking my head when you started off a sentence with "The first hundred devices..."
    It is a good idea to keep a spreadsheet with your device names, IP addresses, and MAC addresses.
    Please mark this as resolved so others can benefit from the discussion.
