tk3000
Aug 21, 2022Aspirant
RAX40 Router unable to assign a reserved IP to some devices (MACs)
Hello, My router normally assigned IP dynamically via its dhcp server. But, in order to keep track of my devices more consistently, I decided to assign specific IP addresses to specific devices (MAC...
- Aug 21, 2022
Salt that sequence away, "once I rebooted the router a second time..." you will use that again in the future.
You had me shaking my head when you started off a sentence with "The first hundred devices..."
It is a good idea to keep a spreadsheet with your device names, IP addresses, and MAC addresses.
Please mark this as resolved so others can benefit from the discussion.
tk3000
It seems that the problem with ping sweep/scan was related to some glitch in the router. Once I rebooted it a second time, the problem went away and a ping sweep shows all devices/nodes in the network.
Also, I was able to reserve IP addresses to devices once the devices were off and the router itself was rebooted.
Thanks!
Kitsap
Aug 21, 2022Master
- tk3000Aug 22, 2022Aspirant
Yeah, I should started the sentence with "the pool of the first 100 IP addresses are kept for the static use, and out of the scope of the dhcpd."
Sure enough, I will mark it as resolved.
