Say_What
Feb 18, 2021Aspirant
RAX40 set up VPN
Good day, I've been enjoying my RAX40 router for years. I have a Surf Shark VPN service that I use on my PC and Android phone. My wife is all Apple, I want to set up my router with VPN. I'm researchi...
Feb 18, 2021Guru - Experienced User
there isn't a surefire way. The RAX devices support openvpn
https://kb.netgear.com/29783/How-do-I-use-VPN-service-on-my-router-with-my-Android-device
Not surf shark.
And it doens't look like surf shark supports having a vpn built into a router. From looking at their site, its designed to be installed to computers/pc/tablets/phones. Not directly to a router. Some vpn's offer custom 3rd party firmware you can install to a router (not the rax ones) so only the router needs the vpn settings.
- Say_WhatFeb 19, 2021Aspirant
Thanks for the advice, do you know of a router that supports SurfShark vpn?
- plemansFeb 19, 2021Guru - Experienced User
I looked up surf shark and they don't have any router based vpn's. Its all installed to the individual devices from what I can tell.
You'd probably get a better response by asking surfshark if they plan on implementing a router based approach or not.
- Arkmantodd84May 07, 2021AspirantSurf Shark customer support rep says it can be set up on the following: R7900, R7000, R6400V2, R6300V2, R6220, & WNDR4300
