EcoDieselDave
Aug 24, 2019Guide
Rax40 setup & access
Can anyone help, messaged Netgear no replies in days, new RAX40 however after Basic set up only changing network names to what I had Prior on my TP-link so I wouldn't need to redo all my TV's or Smar...
Ctanner589
Aug 24, 2019Aspirant
Hey. I was having the EXACT same problem after "upgrading" to the RAX40. Log into your router using an internet browser, click on the Advanced tab, select setup, and then wireless setup. If the box for Enable AX is selected, try to unselect it (disable Ax and OFDMA). Not sure why, but having this enabled made my network go crazy. Maybe because it is something newer? I'm not sure.
EcoDieselDave
Aug 25, 2019Guide
Thank you for this!
I actually wasted a half a day on this Saturday making the mistake of calling in, total of 3+ hours 1 call 5 transfers & 3 techs, & Not a one in the USA & All verifying my info 7 times total, Netgear actually stated the Rax 40 has an issue across the board. They emailed me a link to change firmware & again stated only the Rax 40 had this issue. Not the Rax80 or others.
Not sure if this is fixed it but I greatly appreciate your response. I lost 2x the amount in income this rax40 cost. So If I return it in out $600.
I just need a router that works.
I'll try this also, though I don't know these acronyms or language
I just can't understand why a 10-year-old TP-link the app access is instant, but this Rax40 takes minutes to just connect? Minutes to make changes. Minutes to do it's own speedtest even??
Thank you again
Thank you again
