davelasker
May 21, 2026Aspirant
RAX40 Slow WiFi in AP mode
I've been using my RAX40 with Comcast/Xfinity cable internet. I have 300MB service. Router is connected to CM1000 modem. I consistently get around 350 MB/s from Speedtest on both 2.4 and 5 Ghz. Smart...
- May 22, 2026
I noticed this problem as soon as I switched to AP mode. I tried multiple reboots which didn't help.
However, I am happy to report that since I made the configuration change to 20/40 coexistence I am now consistently getting well over 300 MB/s on 5Ghz. Given I had flakey inconsistent behavior earlier, I believe that my reloading the config was what fixed the problem and had nothing to with 20/40 which only affects 2.4 Ghz. Just to be sure, I turned the option back on and I still get the faster speeds.
I agree with Plemans about slower speeds from 2.4Ghz. I think my memory failed me about seeing faster speeds from it in the past. I'm now getting 50 to 65 MHz/s.
In AP mode, the RAX40 now consistently responds to the routerlogin addresses.
All my tests were done with speedtest.net with the devices about 5 feet away from the RAX40.
Thanks for the help!
CrimpOn
May 21, 2026Guru - Experienced User
I wanted to use Wireguard to access my home network and loaded Wireguard on a Raspberry Pi that was already connected to my LAN. Wireguard uses port 51820, so I forwarded port 51820 through my Netgear router to the Raspberry Pi. No change to the Netgear router. It remains in 'router mode'.
That said, I see no reason why connecting the RAX40 to the Edgerouter should have any effect on the speed of devices connected to the RAX40 WiFi.
