ytching
Aug 21, 2020Tutor
RAX40 SSID disappear
My RAX40's ssid would disappear somtimes. During that case, I am able to access the UI through remote management. In the advanced page, I saw both 2.4G and 5G ssid showing empty. Normally, it should ...
ytching
Aug 22, 2020Tutor
It's the latest version. I also have factory reset it. In my network, there is another old model router configured as a wifi repeater. It is using realtek rtl8812ar as the chipset. I discover that everytime when the old router try to connect to the RAX40. The SSID will be disappeard. Besides, I also discover that when some old devices are trying to connect, it may also make the SSID disappear. Just like what I am saying. It seems that some old model wireless network cards would make the router unstable.
Aug 22, 2020Guru - Experienced User
ytching wrote:It's the latest version.-----a number helps. In case others are having the issue, or if support is watching these forums, or if it isn't the latest. I also have factory reset it. In my network, there is another old model router configured as a wifi repeater. It is using realtek rtl8812ar as the chipset. I discover that everytime when the old router try to connect to the RAX40.----Does it only happen if the old repeater connects? Any issues if you leave the repeater off? The SSID will be disappeard. Besides, I also discover that when some old devices are trying to connect, it may also make the SSID disappear. Just like what I am saying. It seems that some old model wireless network cards would make the router unstable.
- ytchingAug 23, 2020Tutor
V1.0.3.80_1.0.1. Yes, when I take it out, it didn't happen again. However, there are still some minor problems. Most likely can be resolved by disconnect and connect the wifi again. I ignore it first...
- ytchingAug 24, 2020TutorThere are still some annoying issues. Some of my devices are connected to the WiFi but it cannot access to the internet. In window 10 device, it just showed no internet , secured. In iPhone, it just cannot access to the internet. I have tried to ping gateway. However, no response from it. The problem solved until I reconnect the WiFi. It’s annoying especially recent time as I need to work from home. It usually sudden drop when I am having a conference.
- plemansAug 24, 2020Guru - Experienced User
What modem is it connected to?
How big is your home?
What are the interior walls of your home made of?
