ytching
Aug 21, 2020Tutor
RAX40 SSID disappear
My RAX40's ssid would disappear somtimes. During that case, I am able to access the UI through remote management. In the advanced page, I saw both 2.4G and 5G ssid showing empty. Normally, it should ...
ytching
Aug 24, 2020Tutor
A ZTE modem provided by ISP. They just came and check today and said that no problem on it. My home is just around 500 ft. I don’t know what is it make of. However, my PC are always located at the same place which have no walls between the router and it. If I would like to reinstall the router, what are the step? I just realised I did not try a reinstall before. I just think that factory reset is equal to reinstall. I browsed and found that some model of netgear router can be reinstalled by using tftp. Can I apply the same step on RAX40 to try?
Aug 24, 2020Guru - Experienced User
ytching wrote:
A ZTE modem provided by ISP.---Which modem? Some are modem router combo devices. They just came and check today and said that no problem on it. My home is just around 500 ft. I don’t know what is it make of.---knock on it. plaster lathe/brick/concrete is a lot harder than sheetrock However, my PC are always located at the same place which have no walls between the router and it. If I would like to reinstall the router, what are the step? I just realised I did not try a reinstall before. I just think that factory reset is equal to reinstall. I browsed and found that some model of netgear router can be reinstalled by using tftp. Can I apply the same step on RAX40 to try?
I wouldn't go the route of tftp yet. I'd just try either reinstalling the current firmware over a hardwired connection or downgrading a version. I'd then factory reset and reinstall.
