WraithBand
Mar 14, 2020Tutor
RAX40 unlock Wifi region
Hello, I wonder how to change my RAX40 Wifi region. It seems to be locked on "US" and I can't change it at all. Does anyone know how to do it ?
Christian_R
Mar 16, 2020NETGEAR Employee Retired
Hello WraithBand,
The region is set based on the place of purchase of the device.
Christian
ronald_fr
Apr 27, 2020Luminary
Hello WraithBand,
The 1st time I tried to change the location, it didn't work at all ...
But just after one reset to factory defaults, (I did so many), I succed to change it!
Depending on the region, I got differents 5GHz chan available (so it worked)...
You should be able to change region, but for Europe in my case, the contry code is set to "DE" and there is no way to change it.
Regards
Ron
- WraithBandMay 17, 2020TutorHi Ronald !
I tried standard reset (7 seconds on reset button then restart) and hard reset (30 seconds on reset button when on, then 30 sec eith router shut down then 30 sec again when on) and nothing changed :(
My only one region available is United States !- ronald_frMay 18, 2020Luminary
Hello WraithBand,
Perhaps routers available in the US are locked on region US and not the others ?
I can't verify by now as my router is gone (RMA)... But this is strange as I was able to change it with the result being different channels available on 5GHz WiFi.
Best regards
Ron
- WraithBandMay 18, 2020Tutor
Yes cause I bought it on amazon.com so I suppose it's a region's locked model... :(
Thank you anyway for your answers.
Best regards !
