jackroberts's avatar
jackroberts
RAX40 USB Port broken?
Hi I wonder if anyone can help me, I’ve been using the router since December 2021 and everything’s been fine, a few months ago I plugged a Sandisk 256GB USB Flash Drive into it to stream TV shows onto my other devices, in January I upgraded it to a Sandisk 512GB USB Flash Drive, earlier this week we’ve started with WiFi issues (it’s on Virgin Media’s end) and before I knew this I rebooted the router a handful of times using the app and since then I can no longer access the drive from the router, I tried connecting to me laptop to see if the drive was corrupt and no, I tried connecting the old drive that was connected to another device to see if that would work and no, nothing.
Is there anything that can be done or does the router need to be replaced?
  • michaelkenward's avatar
    michaelkenward
    Have you been into the browser graphical user interface (GUI) and investigated the ReadySHARE settings?
    • jackroberts's avatar
      jackroberts
      Hi I've checked all of the settings and I've not had any luck getting it to work. The router isn't really acknowledging that it's even connected.
      • plemans's avatar
        Did you try factory resetting the router? maybe in the on/off's you were doing, something in the settings was corrupted
