jeffo20375
Jun 30, 2020Aspirant
RAX40 V1.0.3.80_1.0.1 is not compatible with Spectrum ISP
All I have been on spectrum ineternet for about 4 months, when my wife was checking the router one day to see if one of the devices was enabled on the nightgear app, she noticed and update button for...
michaelkenward
Jul 01, 2020Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware. It is also the first thing that Netgear support will recommend.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
An alternative is to go back to the older firmware.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- carmineaJul 01, 2020StarThat didn't work. Tried it 5 times and pushed reset pin hole on router.
Have sam3 problems. Even tried an older firmware from website. Doesn't work. The update fried the router.
I'll just switch brands and never buy netgear again, had the router 6 months spent 200 dollars for junk.- michaelkenwardJul 02, 2020Guru - Experienced User
carminea wrote:
Even tried an older firmware from website. Doesn't work. The update fried the router.That doesn't make sense. What does "fried the router" mean?
- carmineaJul 02, 2020StarGoogle the term....
ok, what i learned is to download the older firmware version from Netgear website, look for the older version
V1.03.64_101 and go into the Admin settings of the route and update firmware manually.
After i did that everything works again back to normal. It tooks me a few days of playing with setting and resets, but today i downloaded and tried the older version and it works
give it a try. Also turn off auto updates so it doesnt happen again, and hopefully another update will come out
stay away from 3.80 version, its garabage. something is wrong with that version. It blocks all wifi traffic and you cannot do anything about it in the settings
That's important advice.
- jeffo20375Jul 06, 2020AspirantYes, I tried to revert to factory settings, this did not fix the issue. Only reverting back to and older firmware version fixed the issue.
- carmineaJul 06, 2020StarHere is the main issue, this means we cannot get any future updates that protect us from router vulnerability, after that's what firmware updates do right.
- jeffo20375Jul 09, 2020AspirantWell at least you can test new builds and if it doesn’t work revert back. But yes I was thinking the same thing. Hopefully enough of us are having this issue that Netgear will fix it in the next release.
