jeffo20375
Jun 30, 2020Aspirant
RAX40 V1.0.3.80_1.0.1 is not compatible with Spectrum ISP
All I have been on spectrum ineternet for about 4 months, when my wife was checking the router one day to see if one of the devices was enabled on the nightgear app, she noticed and update button for...
carminea
Jul 01, 2020Star
That didn't work. Tried it 5 times and pushed reset pin hole on router.
Have sam3 problems. Even tried an older firmware from website. Doesn't work. The update fried the router.
I'll just switch brands and never buy netgear again, had the router 6 months spent 200 dollars for junk.
michaelkenward
Jul 02, 2020Guru - Experienced User
That doesn't make sense. What does "fried the router" mean?
- carmineaJul 02, 2020StarGoogle the term....
- michaelkenwardJul 02, 2020Guru - Experienced User
carminea wrote:
Google the term....That is no use whatsoever.
There are specific terms that describe what is happening to a router. For example, "corrupt firmware" is something that everyone understands and that you will see mentioned in manuals.
If you don't want to help, fine. This will indicate to people how much weight to attach to your messages.
