jeffo20375
Jun 30, 2020Aspirant
RAX40 V1.0.3.80_1.0.1 is not compatible with Spectrum ISP
All I have been on spectrum ineternet for about 4 months, when my wife was checking the router one day to see if one of the devices was enabled on the nightgear app, she noticed and update button for...
jeffo20375
Jul 06, 2020Aspirant
Yes, I tried to revert to factory settings, this did not fix the issue. Only reverting back to and older firmware version fixed the issue.
carminea
Jul 06, 2020Star
Here is the main issue, this means we cannot get any future updates that protect us from router vulnerability, after that's what firmware updates do right.
- jeffo20375Jul 09, 2020AspirantWell at least you can test new builds and if it doesn’t work revert back. But yes I was thinking the same thing. Hopefully enough of us are having this issue that Netgear will fix it in the next release.
- KevinepriceJul 09, 2020Aspirant
Since I rolled back to the .64 firmware......all is well again.
With the .80 firmware, I was power-cycling 3-4 times a day to get my SSID's to broadcast again despite the "All green" physical LED indicator lights and the "Good" status on the NetGear Admin tools (mobile & web).
I was looking forward to using the new "SmartConnect" feature to have it manage 2.4GHZ vs 5.0 GHZ....too bad, back to broadcasting both and choosing the default to use based on the connecting device.
Please fix this Netgear. C'mon.....
- Bentl78Jul 31, 2020GuideStill no update on the firmware? It’s been so long and seems so many people are having probs with the new firmware. Does Netgear even look at the issues here?
