jeffo20375
Jun 30, 2020Aspirant
RAX40 V1.0.3.80_1.0.1 is not compatible with Spectrum ISP
All I have been on spectrum ineternet for about 4 months, when my wife was checking the router one day to see if one of the devices was enabled on the nightgear app, she noticed and update button for...
Kevineprice
Jul 08, 2020Aspirant
I ran into this EXACT SAME issue when I applied the new, and recommended, .80 firware update on June 30th.
SAME symptoms and also using Spectrum. Had no issues at all prior to the application of this firmware.
I just downgraded it back to the stable .64 build and disabled autocheck for new versions.
Hoping the 2-3 times a day restart to rebroadcast SSID's stop!
Having a solid, and reliable, Wifi connection in a housefull of teenagers is expected...when it fails, you are the immediate reason why all things are bad in the world.
Netgear.....c'mon, you can do better than this in your firmware updates.
