Mims455
Jan 05, 2022Aspirant
RAX40 v2 DHCP Option
Hello, I just bought the NightHawk RAX40 v2 routeur in order to replace my provider one. To do that, i need the DHCP option 60 and 61. As precised by the following KB article https://kb.netgear.com...
Jan 05, 2022Guru - Experienced User
Something to contact NG support about and see though maybe something that could take a while, even if they might support it:
https://my.netgear.com/support/contact.aspx
You might get something on that list the does fully support that if you need it.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- Mims455Jan 08, 2022Aspirant
- Mims455Jan 09, 2022Aspirant
I guess it is not possible due to architectural evolutions, but does someone know if there is a way to apply the RAX40 v1 firmware to the RAX40 v2 ? (the expected extension file is not the same between the 2 versions...).
Thanks
- plemansJan 09, 2022Guru - Experienced User
don't try it.
the v1 and V2 use different hardware and you'll end up bricking your device if it even lets you "force it"
