Mims455
Jan 05, 2022Aspirant
RAX40 v2 DHCP Option
Hello, I just bought the NightHawk RAX40 v2 routeur in order to replace my provider one. To do that, i need the DHCP option 60 and 61. As precised by the following KB article https://kb.netgear.com...
Mims455
Jan 08, 2022Aspirant
Mims455
Jan 09, 2022Aspirant
I guess it is not possible due to architectural evolutions, but does someone know if there is a way to apply the RAX40 v1 firmware to the RAX40 v2 ? (the expected extension file is not the same between the 2 versions...).
Thanks
- plemansJan 09, 2022Guru - Experienced User
don't try it.
the v1 and V2 use different hardware and you'll end up bricking your device if it even lets you "force it"
