chromerose
Jul 22, 2021Aspirant
RAX40 VOIP setup & Anywhere Access not working
Running version 2.10.5.17 and the latest firmware on an iPad.
The "Anywhere Access" is enabled in the App but no longer working. It worked in the past and not since I had to perform another setup due to connectivity issues we were experiencing. In addition to that, I have no way of accessing advanced settings to prioratize VOIP to better the quality of the calls to the business.
I'd really appreciate it someone could provide me with a solution here. Thanks.
- Christian_RNETGEAR Employee Retired
Hello chromerose,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- chromeroseAspirant
Sadly I'm outside of that window which quite frankly is too small. Netgear should be able to offer at the very least a one year "warranty" if it's confident in its products & services; Costco offers 6 months on electronics and they're not even manufacturers.
