pachan888
Dec 13, 2021Aspirant
Rax40 Wi-Fi signal suddenly missing after update latest firmware 1.0.4.102
Wi-Fi signal missing and cannot activate again although I connect with lan cable via desktop. Reset router to factory default. There is no method to make the Wi-Fi radio work again. I need to fall bac...
RangerX
Dec 16, 2021Apprentice
As an FYI, I have a RAX35 which is the same as the RAX40 without the USB port.
I updated to FW 1.0.4.102 and have had no problems with my wifi. I did not need to do a factory reset after the update either. Your problem may have been a fluke. I suggest you make a backup of your router settings and try installing the update again.
