WilsonNWT
May 11, 2020Aspirant
RAX40 WIFI can't connect internet
Hi Support, I am experiencing a situtation with "connected but no internet" with my RAX40 router since last Saturday (9 May 2020). It works perfectly so far since i bought it last September. ...
- May 14, 2020
Hi Wilson,
You may need to try a factory reset on the router and run through the setup assistant again.
Christian
Christian_R
May 14, 2020NETGEAR Employee Retired
Hi Wilson,
Christian
- WilsonNWTMay 19, 2020AspirantThanks Christian.
The factory reset has to be hold for over 30 seconds or it will just reboot the router without default the setting.
