WilsonNWT's avatar
WilsonNWT
RAX40 WIFI can't connect internet
Hi Support,   I am experiencing a situtation with "connected but no internet" with my RAX40 router since last Saturday (9 May 2020). It works perfectly so far since i bought it last September.   ...
  • Christian_R's avatar
    May 14, 2020
    Hi Wilson,
    You may need to try a factory reset on the router and run through the setup assistant again.
    Christian
