camping147
Sep 04, 2019Guide
RAX40 Wifi Connection Issues with Multiple Devices from Various Manufacturers
I got a RAX40 last month and have had issues since i opened the box. I am running the unit in Access Point (AP) mode. List of issues: With 1.0.2.46 firmware I was not able to use a WPA2 password ...
Christian_R
Sep 05, 2019NETGEAR Employee Retired
Hello camping147,
Thanks for taking the time to post a detailed description of the issues you're experiencing with your router. I'd like for our support team to get in contact with you. If you're interested, please send me a message with your contact info and serial number.
~Christian
- camping147Sep 10, 2019Guide
Talking to support has been useless so far. They just go through their runbooks and don't care about the troubleshooting or investigation I have done so far. I was able to update the firmware to xx.60 but the connection issues still persist. I keep having to turn off and on the router every day or so in order for the devices to connect back to the network. I also was not able to log into the router when in this state. This leads me futher to believe it has something to do with the unit. If someone could put me in contact with someone who can help effectively I would appreciate it.
- JrispoliJun 11, 2020AspirantI have had issues of my wifi dropping since I bought this last year. I kept having Comcast come over and try to fix it because I thought it being new wouldn't have been the issue now I'm seeing people have the same problem as myself. Has anyone had luck on a fix? And isn't it insane that you only have 90 days of customer support? You pay more money for a better product and you can't get decent customer service... What the hell.
- patrickbedgoodJun 11, 2020Apprentice
Did you try the latest firmware that just relased? 1.0.3.80? I appear to have somewhat stable connection with this firmware release.
- ronald_frJun 12, 2020Luminary
Hi
where did you find this f/w ?
Regards
Ron
Firmware Version CheckNo new firmware version available.
