camping147
Sep 04, 2019Guide
RAX40 Wifi Connection Issues with Multiple Devices from Various Manufacturers
I got a RAX40 last month and have had issues since i opened the box. I am running the unit in Access Point (AP) mode. List of issues: With 1.0.2.46 firmware I was not able to use a WPA2 password ...
windmgc
Mar 24, 2020Aspirant
Get the same error, purchased RAX40 three months ago, and all devices continues to drop wifi connection several times in a week. When the problem occurs, wifi signal seems totally disappear and can't be searched. Had to restart the whole router, but wifi configs will get back to factory settings after restart. To be honest RAX40's firmware is totally a nightmare. RAX40 doesn't look like a netgear product at all.
Christian_R
Mar 25, 2020NETGEAR Employee Retired
Hello windmgc,
Welcome to the community! May you try enabling/disabling AX to see if there are any improvements.
Thanks,
Christian
- ronald_frMar 26, 2020Luminary
Hello,
just to share :
I also have many issues with my RAX40 using Firmware Version V1.0.3.64_1.0.1 here in France
- 5G wifi not working after some time
- some devices can't connect >>> reboot fixes
- hangs of whole RAX40
- reset to factory defaults w/o any action
I joined support who asked for monney and I payed for NOTHING!
This product too young is full of bugs.
Best regards.
- ZyonApr 05, 2020Aspirant
Hi,
Same here, buy to work at home ... but it's horrible...
Unusable, disconnect every hour, no 5G on some device, slow speed ....
Try all manipulation found on the forum but nothing work ...
Please Netgear update it ....
- Christian_RApr 07, 2020NETGEAR Employee Retired
Hello Zyon,
If you recently purchased the device your router is provided with 90 days of complimentary support with our support team. Please use the link below to access your complimentary support.
https://www.netgear.com/support/default.aspx
Christian
