camping147's avatar
Sep 04, 2019
RAX40 Wifi Connection Issues with Multiple Devices from Various Manufacturers
I got a RAX40 last month and have had issues since i opened the box.  I am running the unit in Access Point (AP) mode.  List of issues:
  • With 1.0.2.46 firmware I was not able to use a WPA2 password more than ~20 characters.  The webpage would not save the changes to the password past those character limits.  (Its overkill but I use 63 and I don't want to change it to less)
  • Because of this, I downgraded to 1.0.2.44.  The following issues described below are with this version:
  • Not all clients were able to see the SSID or connect to the network.  Most of these problems were alleviated when disabling the "ax" funcationality on the wireless setup config page.
  • However, all wifi devices connected to the network drop and cannot connect back to the network.  In this case, I have to turn off and turn back on the unit for the devices to connect again.  This happens from every few hours to a couple days.  Some devices drop first than others but ultimately they all drop and cannot connect.  The list of devices I have connected to the network by manufacturer:
  • Google homes (various versions)
  • Pixel 3
  • iPhone XR
  • Samsung TV
  • Sony TV
  • Dell laptop
  • Lenovo laptop
  • Nest
  • Nintendo Switch
  • Nintendo WiiU
I previously had a R7000P and never had any drops like this over the course of 5 plus years.  My guess is that since this a new product and Netgear decided to have its users do extended Beta testing that these are issues that need to be resolved via firmware updates.  I hope the firmware developers can notice these items and get them resolved quickly.  The ethernet ports work fine at gig speeds on the unit acting like an unmanaged switch.  If I am travelling I would not be able to access the Nest etc.
  • Even the honer router 3 pro seems to be a better alternative than this box of issues netgear calls a router...
    • itsmehuey's avatar
      itsmehuey
      Luminary
      Is Netgear even doing anything about this or even paying attention to this issue at all??? I’ve had this happen on so many occasions over the last 2 months of owning this router. First time this happened I restarted the router and it went to factory settings. Tonight it happened over and over every street turning the router off and on and restarting it too. On the latest firmware.
        itsmehuey
        Luminary
        'every street' was a typo -- supposed to be 'even after'
  • Same problem here. No problem when there were only a few devices connected. However, when everyone in my family using their devices, both wireless and wired, the router will drop everything and then back on after awhile.
    I am using a 1000M broadband services and was hoping to maximize our internet performance by upgrade the router to RAX40 from a R7000. I was wrong and it is so frustrated as this issue is happening everyday. My router is only a few months old and I have been keeping the firmware up to dated.
    If problem still exist in the next few weeks, I will switch to another band for sure.
  • totally agree with you, I am having similar issue, which make me reboot the router twice a day :@
